Up to 20% off select tools
How To Fix A Leaky Faucet
Views: 12K
View statistics:
Past 24 Hours:
26
Past 7 Days:
122
Past 30 Days:
597
All Time:
11,906
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to stop a leak in a common cartridge faucet.
    1. How To Fix A Leaky Faucet, Cartridge Faucet: step 1, image 1 of 2 How To Fix A Leaky Faucet, Cartridge Faucet: step 1, image 2 of 2
      • Shut off the hot and cold water valves underneath the sink by twisting them clockwise until they are tight.
      • The appearance of these valves will differ from sink to sink, but most operate the same.
      • To test that the water has been completely shut off, try turning on the faucet like you would normally. If no water comes out, you're in luck!
      • When reopening the valves after the repair, leave the faucet in its on position. This will prevent pressurized air from building up in the faucet cartridge.
      Ask FixBot
    2. How To Fix A Leaky Faucet: step 2, image 1 of 3 How To Fix A Leaky Faucet: step 2, image 2 of 3 How To Fix A Leaky Faucet: step 2, image 3 of 3
      • Pull up on the the pop-up drain stopper to seal the sink drain.
      • Place a towel in the sink to catch any excess water or faucet hardware.
      Ask FixBot
    3. How To Fix A Leaky Faucet: step 3, image 1 of 3 How To Fix A Leaky Faucet: step 3, image 2 of 3 How To Fix A Leaky Faucet: step 3, image 3 of 3
      • Use your fingers or a prying tool to remove the plug button from the top of the faucet handle.
      Ask FixBot
    4. How To Fix A Leaky Faucet: step 4, image 1 of 1
      • Use a screwdriver to remove the single handle screw.
      • The number and head type/length of the screws may vary from faucet to faucet.
      Ask FixBot
    5. How To Fix A Leaky Faucet: step 5, image 1 of 3 How To Fix A Leaky Faucet: step 5, image 2 of 3 How To Fix A Leaky Faucet: step 5, image 3 of 3
      • Gently pull the faucet handle up from the rest of the faucet.
      Ask FixBot
    6. How To Fix A Leaky Faucet: step 6, image 1 of 2 How To Fix A Leaky Faucet: step 6, image 2 of 2
      • Remove the temperature limit stop from the top of the cartridge.
      • When removing the temperature limit stop and indexer, take note of their position. The limit stop and indexer determine the maximum temperature that water can reach when coming out of the faucet.
      • Even if you mark the position of the indexer and stop, you may still need to reset the temperature limit after addressing the leak. Follow the instructions for your specific faucet if they are available.
      Ask FixBot
    7. How To Fix A Leaky Faucet: step 7, image 1 of 3 How To Fix A Leaky Faucet: step 7, image 2 of 3 How To Fix A Leaky Faucet: step 7, image 3 of 3
      • Unscrew the bonnet from the faucet.
      Ask FixBot
    8. How To Fix A Leaky Faucet: step 8, image 1 of 2 How To Fix A Leaky Faucet: step 8, image 2 of 2
      • Remove the temperature limit indexer from the top of the cartridge.
      Ask FixBot
    9. How To Fix A Leaky Faucet: step 9, image 1 of 2 How To Fix A Leaky Faucet: step 9, image 2 of 2
      • Use an adjustable wrench to loosen the bonnet nut.
      Ask FixBot
    10. How To Fix A Leaky Faucet: step 10, image 1 of 2 How To Fix A Leaky Faucet: step 10, image 2 of 2
      • Remove the bonnet nut.
      Ask FixBot
    11. How To Fix A Leaky Faucet: step 11, image 1 of 2 How To Fix A Leaky Faucet: step 11, image 2 of 2
      • Remove the cartridge.
      Ask FixBot
    12. How To Fix A Leaky Faucet: step 12, image 1 of 3 How To Fix A Leaky Faucet: step 12, image 2 of 3 How To Fix A Leaky Faucet: step 12, image 3 of 3
      • Remove the cartridge o-rings.
      • If the leak has been coming only from the end of the faucet, replace the cartridge.
      • If the faucet has been leaking from the base or from the faucet handle, replace the o-rings.
      • When installing new o-rings, be sure to properly seat them into the grooves on the underside of the cartridge. A misaligned o-ring can easily cause a new leak.
      Ask FixBot
    13. How To Fix A Leaky Faucet: step 13, image 1 of 2 How To Fix A Leaky Faucet: step 13, image 2 of 2
      • When reinserting the cartridge, be sure that the keys on the cartridge line up with the keys on the base of the faucet.
      Ask FixBot
4 other people completed this guide.
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
1 Guide Comment
I am looking for the brand of the faucet in this picture. We have one faucet and need aerator for it but no brand on it...?
Kittie Finch - Reply Share
Past 24 Hours: 26
Past 7 Days: 122
Past 30 Days: 597
All Time: 11,906
