How To Fix A Hole In Khaki Pants
    1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: step 1, image 1 of 1
      • Examine the damaged area.
      • Make sure to clean all the debris from the tear.
      Ask FixBot
    2. How To Fix A Hole In Khaki Pants: step 2, image 1 of 1
      • Flip your pants inside out.
      Ask FixBot
    3. How To Fix A Hole In Khaki Pants: step 3, image 1 of 1
      • Pinch hole together.
      • Make sure there is no gaps showing.
      Ask FixBot
    4. How To Fix A Hole In Khaki Pants: step 4, image 1 of 1
      • Pin needle and thread through pants.
      • Use more thread than needed so you will have enough.
      • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
      Ask FixBot
    5. How To Fix A Hole In Khaki Pants: step 5, image 1 of 2 How To Fix A Hole In Khaki Pants: step 5, image 2 of 2
      • Pull needle and thread through pants until there is only 2 inches of thread left.
      • Tie a knot at the end of the remaining 2 inches.
      • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
      Ask FixBot
    6. How To Fix A Hole In Khaki Pants: step 6, image 1 of 2 How To Fix A Hole In Khaki Pants: step 6, image 2 of 2
      • Take the needle and pin it through right next to the previous spot.
      • Pull all the way through until thread is tight.
      • Repeat this process until you reach the end of the hole.
      Ask FixBot
    7. How To Fix A Hole In Khaki Pants: step 7, image 1 of 1
      • Wrap the thread three times around the needle.
      • Pull the needle until the thread is tight.
      • This will tie a knot at the end.
      Ask FixBot
    8. How To Fix A Hole In Khaki Pants: step 8, image 1 of 1
      • Take the scissors and cut the excess string remaining.
      Ask FixBot
    9. How To Fix A Hole In Khaki Pants: step 9, image 1 of 1
      • Now put your khaki pants on because they are now wearable again and practically new!
      Ask FixBot
Now your old ripped pants look practically new and you can begin wearing them again.
6 other people completed this guide.
Calvin Roth
291 Reputation
1 Guide authored
Cal Poly, Team 17-1, Green Fall 2015 Member of Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 Members
24 Guides authored
5 Guide Comments
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Reply Share
and 100% maching
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
EMMA MILLER - Reply Share
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Reply Share
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 152
All Time: 54,169
