How To Fix A Broken Makeup Brush
Views: 7.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
36
Past 30 Days:
133
All Time:
7,112
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Broken makeup brushes are a common issue and can be expensive to replace. We have composed a simple 5 step guide on how to quickly fix a broken makeup brush. Prior to beginning the fast fix, be sure to plug in the hot glue gun for at least 5 minutes to allow it to reach adequate temperature.
    1. How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: step 1, image 1 of 2 How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: step 1, image 2 of 2
      • Remove excess glue on the handle and the base of the brush using a nail file.
      Ask FixBot
    2. How To Fix A Broken Makeup Brush: step 2, image 1 of 1
      • Use the hot glue gun to apply glue to the inside base of the brush where the handle is attached.
      • Be cautious of the high temperature of the glue and gun when handling.
      Ask FixBot
    3. How To Fix A Broken Makeup Brush: step 3, image 1 of 1
      • Slowly place the brush head onto the handle and apply pressure for 15 seconds.
      Ask FixBot
    4. How To Fix A Broken Makeup Brush: step 4, image 1 of 1
      • Remove excess glue from the brush using a paper towel.
      Ask FixBot
    5. How To Fix A Broken Makeup Brush: step 5, image 1 of 1
      • Let the glue dry for 2-3 minutes to be sure it is securely attached.
      Ask FixBot
Finish Line
Shanae Swack
409 Reputation
1 Guide authored
Texas Tech, Team 26-4, Rauch Spring 2016 Member of Texas Tech, Team 26-4, Rauch Spring 2016
TTU-RAUCH-S16S26G4
3 Members
12 Guides authored
1 Guide Comment
Amazing!!! Thanks a lot.
Amal - Reply Share
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 133
All Time: 7,112
