Up to 20% off select tools
Hoverboard Bluetooth Remote Control Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
135
All Time:
2,803
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the Bluetooth remote control of a Hoverboard.
Be careful! A soldering iron is used in this guide, so take the necessary precautions before starting
    1. Hoverboard Bluetooth Remote Control Replacement, Bluetooth Remote Control: step 1, image 1 of 1
      • Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
      • The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
      Ask FixBot
    2. Hoverboard Bluetooth Remote Control Replacement: step 2, image 1 of 1
      • Unhook the lighting and indicator light wires to remove the cover.
      Ask FixBot
    3. Hoverboard Bluetooth Remote Control Replacement: step 3, image 1 of 1
      • Remove the 4 screws that hold the circuit board support.
      Ask FixBot
    4. Hoverboard Bluetooth Remote Control Replacement: step 4, image 1 of 1
      • Remove the 4 screws that secure the board to the support.
      Ask FixBot
    5. Hoverboard Bluetooth Remote Control Replacement: step 5, image 1 of 1
      • Remember the sequence of wires to be soldered on the Bluetooth board.
      Ask FixBot
    6. Hoverboard Bluetooth Remote Control Replacement: step 6, image 1 of 1
      • Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
      • Before soldering the boards, check the functionality of the Bluetooth board by merely inserting the pins, which is enough.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Smilzo
12,407 Reputation
39 Guides authored
4 Guide Comments
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - Reply Share
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo - Reply Share
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
https://www.amazon.it/Hoverboard-Telecom...
https://www.ebay.it/itm/REPLACEMENT-REMO...
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 135
All Time: 2,803
