Up to 20% off select tools
Hover-1 XLS LCD Screen Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
102
All Time:
2,514
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LCD Screen displays the status of the bike and is a clear indicator if your bike is on or off. Before beginning this replacement, you should know that it is a prerequisite to get to the ignition off. To get to the ignition, follow the ignition guide. You should also be able to solder. If you don't know how to solder, just follow the soldering guide in iFixit.
    1. Hover-1 XLS LCD Screen Replacement, Ignition: step 1, image 1 of 1
      • Remove the six 16mm #3 Hex head screws located on the front panel.
      • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
      Ask FixBot
    2. Hover-1 XLS LCD Screen Replacement: step 2, image 1 of 3 Hover-1 XLS LCD Screen Replacement: step 2, image 2 of 3 Hover-1 XLS LCD Screen Replacement: step 2, image 3 of 3
      • Grab the front panel and gently lift it up to the side.
      • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
      Ask FixBot
    3. Hover-1 XLS LCD Screen Replacement: step 3, image 1 of 1
      • Remove the two, 19 mm Phillips #2 screws holding the ignition.
      • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
      Ask FixBot
    1. Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 1 of 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 2 of 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 3 of 3
      • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
      • Remove the casing on the LCD.
      Ask FixBot
    2. Hover-1 XLS LCD Screen Replacement: step 5, image 1 of 3 Hover-1 XLS LCD Screen Replacement: step 5, image 2 of 3 Hover-1 XLS LCD Screen Replacement: step 5, image 3 of 3
      • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
      • Gently lift off the LCD screen.
      • Follow iFixit's soldering guide to remove the LCD screen.
      Ask FixBot
Author
with
Jonathan Hidalgo
686 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 102
All Time: 2,514
