Hover-1 Ultra Charging Port Replacement
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: step 1, image 1 of 3 Hover-1 Ultra Charging Port Replacement, Charging Port: step 1, image 2 of 3 Hover-1 Ultra Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
    Ask FixBot
  2. Hover-1 Ultra Charging Port Replacement: step 2, image 1 of 2 Hover-1 Ultra Charging Port Replacement: step 2, image 2 of 2
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
    Ask FixBot
  3. Hover-1 Ultra Charging Port Replacement: step 3, image 1 of 3 Hover-1 Ultra Charging Port Replacement: step 3, image 2 of 3 Hover-1 Ultra Charging Port Replacement: step 3, image 3 of 3
    • Unclip the insulated red and black wires attached to the port from the motherboard
    Ask FixBot
  4. Hover-1 Ultra Charging Port Replacement: step 4, image 1 of 3 Hover-1 Ultra Charging Port Replacement: step 4, image 2 of 3 Hover-1 Ultra Charging Port Replacement: step 4, image 3 of 3
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
    Ask FixBot
To reassemble your device, follow the instructions for step 1 in reverse order.
3 other people completed this guide.
Camron Clifton
430 Reputation
3 Guides authored
UC Davis, Team S7-G5, Lore Fall 2018 Member of UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,197
