Hover-1 Titan Right Gyroscope Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
73
All Time:
1,965
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your hoverboard will not turn on, retain a charge, move, or spin properly, use this guide to help replace your Hover-1 Titan gyroscope/motherboard.
Tools
    1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: step 1, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: step 1, image 2 of 2
      • Flip the hoverboard so the bottom is facing up.
      • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
      Ask FixBot
    2. Hover-1 Titan Right Gyroscope Replacement: step 2, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
      • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
      • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
      Ask FixBot
    3. Hover-1 Titan Right Gyroscope Replacement: step 3, image 1 of 3 Hover-1 Titan Right Gyroscope Replacement: step 3, image 2 of 3 Hover-1 Titan Right Gyroscope Replacement: step 3, image 3 of 3
      • Grip the bottom right panel and lift to remove it.
      Ask FixBot
    1. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: step 4, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: step 4, image 2 of 2
      • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
      Ask FixBot
    2. Hover-1 Titan Right Gyroscope Replacement: step 5, image 1 of 3 Hover-1 Titan Right Gyroscope Replacement: step 5, image 2 of 3 Hover-1 Titan Right Gyroscope Replacement: step 5, image 3 of 3
      • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
      Ask FixBot
    3. Hover-1 Titan Right Gyroscope Replacement: step 6, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 6, image 2 of 2
      • Unplug the bottom left connector by squeezing it and pulling it away from the board.
      Ask FixBot
    4. Hover-1 Titan Right Gyroscope Replacement: step 7, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 7, image 2 of 2
      • Unplug the white wires by squeezing the connector and pulling away from the board.
      Ask FixBot
    5. Hover-1 Titan Right Gyroscope Replacement: step 8, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 8, image 2 of 2
      • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
      Ask FixBot
    6. Hover-1 Titan Right Gyroscope Replacement: step 9, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 9, image 2 of 2
      • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
      Ask FixBot
    7. Hover-1 Titan Right Gyroscope Replacement: step 10, image 1 of 1
      • Cut the cable tie and unplug the remaining wires.
      Ask FixBot
2 other people completed this guide.
Jessica Ouyang
634 Reputation
4 Guides authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
96 Guides authored
1 Guide Comment
Where can I get the circuit boards for the left and right ?
jfsucher - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 73
All Time: 1,965
