Hover-1 Superstar Speaker Replacement
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: step 1, image 1 of 3 Hover-1 Superstar Speaker Replacement, Bottom Case: step 1, image 2 of 3 Hover-1 Superstar Speaker Replacement, Bottom Case: step 1, image 3 of 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
    Ask FixBot
  2. Hover-1 Superstar Speaker Replacement: step 2, image 1 of 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    Ask FixBot
  3. Hover-1 Superstar Speaker Replacement, Speaker: step 3, image 1 of 1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
    Ask FixBot
  4. Hover-1 Superstar Speaker Replacement: step 4, image 1 of 1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
    Ask FixBot
  5. Hover-1 Superstar Speaker Replacement: step 5, image 1 of 1
    • Remove the speaker from its port.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 62
All Time: 534
