Hover-1 Superstar Front Bumper LED Replacement
    1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 1 of 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 2 of 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 3 of 3
      • Flip your Hover-1 Superstar device upside down.
      • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
      • Remove the bottom case. Be careful of the connector holding the case and the device together.
      Ask FixBot
    2. Hover-1 Superstar Front Bumper LED Replacement: step 2, image 1 of 1
      • Locate the cable connected to the front lights.
      • Pull apart the wires until the black clip separates.
      Ask FixBot
    1. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: step 3, image 1 of 1
      • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 558
