Hover-1 Nomad Power Button Replacement
    1. Hover-1 Nomad Power Button Replacement, Outer Shell: step 1, image 1 of 3 Hover-1 Nomad Power Button Replacement, Outer Shell: step 1, image 2 of 3 Hover-1 Nomad Power Button Replacement, Outer Shell: step 1, image 3 of 3
      • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
      • Remove the following twenty screws by rotating the screwdriver counterclockwise:
      • Eight 16.2mm Phillips #2 screws
      • Eight 15mm Phillips #2 screws
      • Four 19.1mm Phillips #2 screws
      • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
      • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
      Ask FixBot
    2. Hover-1 Nomad Power Button Replacement: step 2, image 1 of 3 Hover-1 Nomad Power Button Replacement: step 2, image 2 of 3 Hover-1 Nomad Power Button Replacement: step 2, image 3 of 3
      • Use a nylon spudger to pry the metal handle away from the outer shell.
      • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
      • Lift the hoverboard off the metal handle.
      • Repeat for the handle on the other side of the hoverboard.
      Ask FixBot
    3. Hover-1 Nomad Power Button Replacement: step 3, image 1 of 1
      • Lift the plastic cover on each side up and away from the device.
      • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
      Ask FixBot
    4. Hover-1 Nomad Power Button Replacement: step 4, image 1 of 2 Hover-1 Nomad Power Button Replacement: step 4, image 2 of 2
      • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
      • Charging port wires
      • Speaker assembly wires
      • Power button wires
      • Headlight wires
      • Only the headlight wires need to be disconnected from the other circuit board.
      • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
      Ask FixBot
    1. Hover-1 Nomad Power Button Replacement, Power Button: step 5, image 1 of 2 Hover-1 Nomad Power Button Replacement, Power Button: step 5, image 2 of 2
      • Peel off the glue around the power button.
      • Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
      Ask FixBot
    2. Hover-1 Nomad Power Button Replacement: step 6, image 1 of 1
      • Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
      Ask FixBot
Samuel Frazee
1,015 Reputation
7 Guides authored
Cal Poly, Team S15-G1, White Fall 2018 Member of Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 686
