Hover-1 Maverick Battery Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
28
Past 30 Days:
92
All Time:
4,252
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide for the Hover-1 Maverick guides users in replacing the battery in their device. The battery is crucial in powering the hoverboard. Symptoms of having a faulty battery include the device not being able to move, hold a charge, or power on.
Before you begin, make sure your Hover-1 Maverick is off and not charging.
Parts
Tools
    1. Hover-1 Maverick Battery Replacement, Battery: step 1, image 1 of 2 Hover-1 Maverick Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
      • Remove the shell.
      Ask FixBot
    2. Hover-1 Maverick Battery Replacement: step 2, image 1 of 3 Hover-1 Maverick Battery Replacement: step 2, image 2 of 3 Hover-1 Maverick Battery Replacement: step 2, image 3 of 3
      • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
      • Lift off the black plastic retaining bracket.
      Ask FixBot
    3. Hover-1 Maverick Battery Replacement: step 3, image 1 of 2 Hover-1 Maverick Battery Replacement: step 3, image 2 of 2
      • Pull the battery upward lightly to remove from the device.
      • The battery is secured to the device with adhesive tape.
      Ask FixBot
Piper Feldman
409 Reputation
4 Guides authored
Cal Poly, Team S2-G2, White Winter 2020 Member of Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Members
48 Guides authored
2 Guide Comments
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - Reply Share
Where can I find that same battery i cant find one
Toad Blue - Reply Share
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 92
All Time: 4,252
