Up to 20% off select tools
Hover-1 Matrix Pad Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
73
All Time:
1,037
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The pads on Hover-1 Matrix are weight sensitive, so when they sense weight, the hover board starts to move automatically. Overused pads must be replaced for the Hover-1 Matrix to move when there is a rider.
    1. Hover-1 Matrix Pad Replacement, Pad: step 1, image 1 of 2 Hover-1 Matrix Pad Replacement, Pad: step 1, image 2 of 2
      • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
      • Remove the back shell from the hoverboard.
      Ask FixBot
    2. Hover-1 Matrix Pad Replacement: step 2, image 1 of 1
      • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
      Ask FixBot
    3. Hover-1 Matrix Pad Replacement: step 3, image 1 of 1
      • Separate the upper shell of the hoverboard and the metal layer inside.
      Ask FixBot
    4. Hover-1 Matrix Pad Replacement: step 4, image 1 of 2 Hover-1 Matrix Pad Replacement: step 4, image 2 of 2
      • Start by identifying the motherboard, which is the green pad shown in the picture.
      • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
      • There are cables attached to the motherboard so go ahead and unattach them.
      Ask FixBot
    5. Hover-1 Matrix Pad Replacement: step 5, image 1 of 3 Hover-1 Matrix Pad Replacement: step 5, image 2 of 3 Hover-1 Matrix Pad Replacement: step 5, image 3 of 3
      • Use picture 1 as a guide and move the motherboard to the other side.
      • Identify the two black rubber buttons that are shown in the second picture.
      • Remove the two rubber buttons using the Phillips #1 screwdriver.
      Ask FixBot
    6. Hover-1 Matrix Pad Replacement: step 6, image 1 of 1
      • Removing the rubber buttons in the previous step allows you to take the pad off.
      • Finally, take off the old pad and put on a new pad.
      Ask FixBot
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Author
with
Jici Zhuang
362 Reputation
2 Guides authored
UC Davis, Team S7-G2, Lore Fall 2018 Member of UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 73
All Time: 1,037
