Up to 20% off select tools
Hover-1 Horizon Power Button Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
74
All Time:
1,099
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Does your Hover-1 Horizon not turn off? This is a guide to show you how to replace the power button, the most likely cause of your issue. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
    1. Hover-1 Horizon Power Button Replacement, Base Plate: step 1, image 1 of 2 Hover-1 Horizon Power Button Replacement, Base Plate: step 1, image 2 of 2
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      Ask FixBot
    2. Hover-1 Horizon Power Button Replacement: step 2, image 1 of 2 Hover-1 Horizon Power Button Replacement: step 2, image 2 of 2
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      Ask FixBot
    3. Hover-1 Horizon Power Button Replacement: step 3, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 3, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 3, image 3 of 3
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      Ask FixBot
    1. Hover-1 Horizon Power Button Replacement, Power Button: step 4, image 1 of 1
      • Reorient the Hover-1 Horizon so the base plate opens towards you.
      Ask FixBot
    2. Hover-1 Horizon Power Button Replacement: step 5, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 5, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 5, image 3 of 3
      • Remove the connector by squeezing the tab and lifting up.
      Ask FixBot
    3. Hover-1 Horizon Power Button Replacement: step 6, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 6, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 6, image 3 of 3
      • Remove the second connector by squeezing the tab and pulling up.
      Ask FixBot
    4. Hover-1 Horizon Power Button Replacement: step 7, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 7, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 7, image 3 of 3
      • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
      • Push the power button through the base plate to remove.
      • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
      Ask FixBot
Author
with
Christina Fong
165 Reputation
1 Guide authored
Cal Poly, Team S13-G6, White Fall 2018 Member of Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 74
All Time: 1,099
