Hover-1 Horizon Left Balancing Sensor Replacement
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: step 1, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: step 1, image 2 of 2
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      Ask FixBot
    2. Hover-1 Horizon Left Balancing Sensor Replacement: step 2, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 2, image 2 of 2
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      Ask FixBot
    3. Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 3 of 3
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      Ask FixBot
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 3 of 3
      • Remove the two connectors on either side of the board by lifting the tab and pulling out.
      • Remove the connector in the middle of the board by squeezing the tab and pulling up.
      Ask FixBot
    2. Hover-1 Horizon Left Balancing Sensor Replacement: step 5, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 5, image 2 of 2
      • Remove the four 11mm Phillips #1 screws that hold the cover on.
      Ask FixBot
    3. Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 3 of 3
      • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
      • Lift the board to reveal the connections on the bottom.
      Ask FixBot
    4. Hover-1 Horizon Left Balancing Sensor Replacement: step 7, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 7, image 2 of 2
      • Remove the middle connector by squeezing the top of the tab and pulling up.
      Ask FixBot
    5. Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 3 of 3
      • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
      • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
      Ask FixBot
    6. Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 3 of 3
      • Unclip the black connector by squeezing both sides and pulling them apart.
      Ask FixBot
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 3 of 3
      • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
      • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
      Ask FixBot
    2. Hover-1 Horizon Left Balancing Sensor Replacement: step 11, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 11, image 2 of 2
      • Remove the sensor tab by carefully lifting it away from the hoverboard.
      Ask FixBot
Jesus
85 Reputation
1 Guide authored
Cal Poly, Team S13-G6, White Fall 2018 Member of Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,613
