Tools
Introduction
Go to step 1 ↓This guide explains how to replace the shell of your Hover-1 H1 hoverboard.
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
Pull the cable through the center section of the hoverboard.
Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
