Tools
Introduction
Go to step 1 ↓Replacing the power button of your Hover-1 H1 hoverboard can help with problems involving turning on your device.
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
Pull the cable through the center section of the hoverboard.
