Hover-1 H1 LED Headlight Replacement
    1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: step 1, image 1 of 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Ask FixBot
    2. Hover-1 H1 LED Headlight Replacement: step 2, image 1 of 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Ask FixBot
    3. Hover-1 H1 LED Headlight Replacement: step 3, image 1 of 2 Hover-1 H1 LED Headlight Replacement: step 3, image 2 of 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Ask FixBot
    4. Hover-1 H1 LED Headlight Replacement: step 4, image 1 of 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Ask FixBot
    1. Hover-1 H1 LED Headlight Replacement, LED Headlights: step 5, image 1 of 1
      • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
      Ask FixBot
    2. Hover-1 H1 LED Headlight Replacement: step 6, image 1 of 1
      • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
      Ask FixBot
    3. Hover-1 H1 LED Headlight Replacement: step 7, image 1 of 1
      • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
      • Remove the horizontal light by using your fingers to pull the light up out of the shell.
      Ask FixBot
Sara Passantino
347 Reputation
2 Guides authored
Cal Poly, Team S17-G6, White Fall 2018 Member of Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,738
