Hover-1 H1 Charging Port Replacement
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: step 1, image 1 of 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Ask FixBot
  2. Hover-1 H1 Charging Port Replacement: step 2, image 1 of 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Ask FixBot
  3. Hover-1 H1 Charging Port Replacement: step 3, image 1 of 2 Hover-1 H1 Charging Port Replacement: step 3, image 2 of 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    Ask FixBot
  4. Hover-1 H1 Charging Port Replacement: step 4, image 1 of 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
    Ask FixBot
  5. Hover-1 H1 Charging Port Replacement, Charging Port: step 5, image 1 of 2 Hover-1 H1 Charging Port Replacement, Charging Port: step 5, image 2 of 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
    Ask FixBot
  6. Hover-1 H1 Charging Port Replacement: step 6, image 1 of 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
    Ask FixBot
  7. Hover-1 H1 Charging Port Replacement: step 7, image 1 of 2 Hover-1 H1 Charging Port Replacement: step 7, image 2 of 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
    Ask FixBot
  8. Hover-1 H1 Charging Port Replacement: step 8, image 1 of 2 Hover-1 H1 Charging Port Replacement: step 8, image 2 of 2
    • Pull the charging port to the left through the shell.
    Ask FixBot
Madeline David
300 Reputation
2 Guides authored
Cal Poly, Team S17-G6, White Fall 2018 Member of Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Members
9 Guides authored
2 Guide Comments
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Reply Share
Who can I contact to fix this charging port on this H one hover one hover board
Hover1 h1 hoverboard - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 47
All Time: 4,989
