Hover-1 H1 Battery Replacement
    1. Hover-1 H1 Battery Replacement, Bottom Shell: step 1, image 1 of 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Ask FixBot
    2. Hover-1 H1 Battery Replacement: step 2, image 1 of 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Ask FixBot
    3. Hover-1 H1 Battery Replacement: step 3, image 1 of 2 Hover-1 H1 Battery Replacement: step 3, image 2 of 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Ask FixBot
    4. Hover-1 H1 Battery Replacement: step 4, image 1 of 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Ask FixBot
    1. Hover-1 H1 Battery Replacement, Battery: step 5, image 1 of 1
      • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
      Ask FixBot
    2. Hover-1 H1 Battery Replacement: step 6, image 1 of 1
      • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
      Ask FixBot
5 other people completed this guide.
Aaron Teh
491 Reputation
2 Guides authored
Cal Poly, Team S17-G6, White Fall 2018 Member of Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Members
84 Guides authored
15 Guide Comments
The stickers were the trick. I didn’t see them!
Daniel D - Reply Share
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - Reply Share
Where do I get another battery to replace it???
Tony Pate - Reply Share
That's the question I can't seem to find the answer to
Darin - Reply Share
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 109
All Time: 13,799
