Hover-1 Chrome Outer Shell Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
77
All Time:
855
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
To fully access all parts of the Hover-1 Chrome, the entirety of the outer shell must be removed. This guide will go over how to completely remove the outer shell.
Tools
    1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: step 1, image 1 of 1
      • Flip the Hover-1 Chrome upside down.
      • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
      • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
      Ask FixBot
    2. Hover-1 Chrome Outer Shell Replacement: step 2, image 1 of 1
      • Lift the shell without the speaker grille and unplug the battery.
      Ask FixBot
    3. Hover-1 Chrome Outer Shell Replacement: step 3, image 1 of 2 Hover-1 Chrome Outer Shell Replacement: step 3, image 2 of 2
      • Lift the shell with the speaker grille.
      • Unplug the speaker.
      • Unplug the LEDs.
      • Unplug the power button
      • Unplug the charging port.
      Ask FixBot
    1. Hover-1 Chrome Outer Shell Replacement, Outer Shell: step 4, image 1 of 1
      • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
      • The other six screws are on the side without the battery.
      Ask FixBot
    2. Hover-1 Chrome Outer Shell Replacement: step 5, image 1 of 3 Hover-1 Chrome Outer Shell Replacement: step 5, image 2 of 3 Hover-1 Chrome Outer Shell Replacement: step 5, image 3 of 3
      • Free the cables held atop the bracket holding the battery in place.
      • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
      • Pull the battery bracket free.
      Ask FixBot
    3. Hover-1 Chrome Outer Shell Replacement: step 6, image 1 of 1
      • Unplug the cords for the top LEDs.
      • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
      Ask FixBot
    4. Hover-1 Chrome Outer Shell Replacement: step 7, image 1 of 1
      • Turn the board over and pull the top panel off.
      Ask FixBot
Finish Line
Dylan Prins
212 Reputation
1 Guide authored
Cal Poly, Team S4-G1, White Fall 2018 Member of Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Members
72 Guides authored
1 Guide Comment
Where can i get a replacement shell?
born4roblox - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 77
All Time: 855
