Hover-1 Chrome LED Headlights Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
43
All Time:
637
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the LED headlights on the front of the Hover-1 Chrome. You will need a Phillips #2 screwdriver.
Tools
    1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: step 1, image 1 of 1
      • Flip the Hover-1 Chrome upside down.
      • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
      • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
      Ask FixBot
    2. Hover-1 Chrome LED Headlights Replacement: step 2, image 1 of 1
      • Lift the shell without the speaker grille and unplug the battery.
      Ask FixBot
    3. Hover-1 Chrome LED Headlights Replacement: step 3, image 1 of 2 Hover-1 Chrome LED Headlights Replacement: step 3, image 2 of 2
      • Lift the shell with the speaker grille.
      • Unplug the speaker.
      • Unplug the LEDs.
      • Unplug the power button
      • Unplug the charging port.
      Ask FixBot
    1. Hover-1 Chrome LED Headlights Replacement, LED Headlights: step 4, image 1 of 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: step 4, image 2 of 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
      • Remove the LED board.
      • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
      Ask FixBot
    2. Hover-1 Chrome LED Headlights Replacement: step 5, image 1 of 2 Hover-1 Chrome LED Headlights Replacement: step 5, image 2 of 2
      • Locate the LED headlights on the left side of the board.
      • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
      Ask FixBot
    3. Hover-1 Chrome LED Headlights Replacement: step 6, image 1 of 3 Hover-1 Chrome LED Headlights Replacement: step 6, image 2 of 3 Hover-1 Chrome LED Headlights Replacement: step 6, image 3 of 3
      Ask FixBot
Nick McGuire
551 Reputation
4 Guides authored
Cal Poly, Team S4-G1, White Fall 2018 Member of Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 43
All Time: 637
