Hover-1 Chrome Battery Replacement
    1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: step 1, image 1 of 1
      • Flip the Hover-1 Chrome upside down.
      • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
      • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
      Ask FixBot
    2. Hover-1 Chrome Battery Replacement: step 2, image 1 of 1
      • Lift the shell without the speaker grille and unplug the battery.
      Ask FixBot
    3. Hover-1 Chrome Battery Replacement: step 3, image 1 of 2 Hover-1 Chrome Battery Replacement: step 3, image 2 of 2
      • Lift the shell with the speaker grille.
      • Unplug the speaker.
      • Unplug the LEDs.
      • Unplug the power button
      • Unplug the charging port.
      Ask FixBot
    1. Hover-1 Chrome Battery Replacement, Battery: step 4, image 1 of 1
      • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
      • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
      • Use the spudger to pry the battery loose from the adhesive.
      Ask FixBot
    2. Hover-1 Chrome Battery Replacement: step 5, image 1 of 2 Hover-1 Chrome Battery Replacement: step 5, image 2 of 2
      • Pull and wiggle the battery completely off of the adhesive using your hands.
      • Remove the battery from the body.
      Ask FixBot
Nick McGuire
551 Reputation
4 Guides authored
Cal Poly, Team S4-G1, White Fall 2018 Member of Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 48
All Time: 1,300
