Up to 20% off select tools
Hover-1 Charger Outer Shell Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
65
All Time:
1,040
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the outer shell of your Hover-1 Charger (H1-COL) is damaged, it may have to be replaced. This guide details instructions to completely remove the outer shell.
In this guide, the right or left cover refers to the portion of the outer shell that contains the LED headlights. The right or left foot pad refers to the portion of the outer shell that the user places their foot on.
Make sure to wear an anti-static wrist strap to protect the electronics against buildup of static electricity. Some screw housings are fragile; they may fall apart when the screw is removed.
    1. Hover-1 Charger Outer Shell Replacement, Outer Shell: step 1, image 1 of 2 Hover-1 Charger Outer Shell Replacement, Outer Shell: step 1, image 2 of 2
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      Ask FixBot
    2. Hover-1 Charger Outer Shell Replacement: step 2, image 1 of 1
      • Pull the right cover away from the hoverboard.
      Ask FixBot
    3. Hover-1 Charger Outer Shell Replacement: step 3, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 3, image 2 of 2
      • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
      • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
      • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
      Ask FixBot
    4. Hover-1 Charger Outer Shell Replacement: step 4, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 4, image 2 of 2
      • Unplug the battery by disconnecting the two pronged black and yellow cable.
      Ask FixBot
    5. Hover-1 Charger Outer Shell Replacement: step 5, image 1 of 3 Hover-1 Charger Outer Shell Replacement: step 5, image 2 of 3 Hover-1 Charger Outer Shell Replacement: step 5, image 3 of 3
      • Unplug the black, yellow, green and red four pin connector from the circuit board.
      • Unplug the red and black two pin connector from the circuit board.
      Ask FixBot
    6. Hover-1 Charger Outer Shell Replacement: step 6, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 6, image 2 of 2
      • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
      • Remove the right foot pad from the hoverboard.
      Ask FixBot
    7. Hover-1 Charger Outer Shell Replacement: step 7, image 1 of 1
      • Pull the left cover away from the hoverboard.
      Ask FixBot
    8. Hover-1 Charger Outer Shell Replacement: step 8, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 8, image 2 of 2
      • Unplug the red and white five pin connector from the circuit board.
      • Thread this connector through the middle cylinder.
      • Remove the right cover from the hoverboard.
      Ask FixBot
    9. Hover-1 Charger Outer Shell Replacement: step 9, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 9, image 2 of 2
      • Unplug the red and white four pin connector from the speaker circuit board.
      • Unplug the blue and white three pin connector.
      • Unplug the blue and white two pin connector. This is photographed as an example.
      Ask FixBot
    10. Hover-1 Charger Outer Shell Replacement: step 10, image 1 of 1
      • Remove the left cover from the hoverboard.
      Ask FixBot
    11. Hover-1 Charger Outer Shell Replacement: step 11, image 1 of 2 Hover-1 Charger Outer Shell Replacement: step 11, image 2 of 2
      • Disconnect the two pronged black and yellow cable.
      Ask FixBot
    12. Hover-1 Charger Outer Shell Replacement: step 12, image 1 of 3 Hover-1 Charger Outer Shell Replacement: step 12, image 2 of 3 Hover-1 Charger Outer Shell Replacement: step 12, image 3 of 3
      • Remove three black and red two pin connectors from the left circuit board.
      • Remove the red, yellow, and black three pin connector.
      • Remove zip tie if present.
      Ask FixBot
    13. Hover-1 Charger Outer Shell Replacement: step 13, image 1 of 1
      • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
      • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    14. Hover-1 Charger Outer Shell Replacement: step 14, image 1 of 1
      • Remove the left foot pad from the hoverboard.
      Ask FixBot
Author
with
Mark Rapiz
253 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Regan Fall 2019 Member of Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Members
72 Guides authored
1 Guide Comment
Where do I buy the shell their website doesnt have it
firestineanthony - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 65
All Time: 1,040
