Introduction
Go to step 1 ↓If you are having trouble balancing on your Hover-1 Charger (H1-COL), there may be an issue with its gyroscope sensor boards. Before you begin disassembling your hoverboard, check out our troubleshooting page addressing hoverboard balancing. If the problem persists, this guide will help you replace your hoverboard’s right gyroscope sensor board. Removal of the left gyroscope sensor board will follow very similar steps.
Make sure to wear an anti-static wrist strap to protect the electronics against buildup of static electricity. Some screw housings are fragile; they may fall apart when the screw is removed.
Tools
Flip the hoverboard over so that the warning label is facing up.
Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
Remove the four 10 mm screws with a Phillips #2 screwdriver.
Unplug the white five pin connector from the gyroscope sensor board.
Unplug the red, yellow, blue, green, black and white six pin connector.
Unplug the black and red two pin connector.
Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
2 other people completed this guide.
5 Guide Comments
Hi Where can I find the replacement sensor board? Thanks!
where do i find the replacement sensor board?
one wheel of my board doesn’t work
I need one of these replacement gyros please how I get
this is a joke. 2 years still not one kind enough soul to help find where to purchase replacements!!!!!!!!
