Hover-1 Charger Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
92
All Time:
10,762
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Hover-1 Charger (H1-COL) is having problems powering on or retaining a charge, there may be an issue with its battery. Before you begin disassembling your hoverboard, check out our troubleshooting pages that address powering on and problems with charging. Make sure to examine your hoverboard’s charger as well. If the problem persists, this guide will help you replace your hoverboard’s battery.
The battery is held in place with adhesive; some force is required to remove it. Make sure to wear an anti-static wrist strap to protect the electronics against buildup of static electricity. Some screw housings are fragile; they may fall apart when the screw is removed.
Tools
    1. Hover-1 Charger Battery Replacement, Battery: step 1, image 1 of 2 Hover-1 Charger Battery Replacement, Battery: step 1, image 2 of 2
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      Ask FixBot
    2. Hover-1 Charger Battery Replacement: step 2, image 1 of 1
      • Pull the right cover away from the hoverboard to expose the battery.
      Ask FixBot
    3. Hover-1 Charger Battery Replacement: step 3, image 1 of 2 Hover-1 Charger Battery Replacement: step 3, image 2 of 2
      • Unplug the battery by disconnecting the two pronged black and yellow cable.
      Ask FixBot
    4. Hover-1 Charger Battery Replacement: step 4, image 1 of 1
      • Pull the left cover away from the hoverboard.
      Ask FixBot
    5. Hover-1 Charger Battery Replacement: step 5, image 1 of 2 Hover-1 Charger Battery Replacement: step 5, image 2 of 2
      • Disconnect the two pronged black and yellow cable.
      • Thread the cable through the middle cylinder of the hoverboard.
      Ask FixBot
    6. Hover-1 Charger Battery Replacement: step 6, image 1 of 2 Hover-1 Charger Battery Replacement: step 6, image 2 of 2
      • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
      • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
      Ask FixBot
    7. Hover-1 Charger Battery Replacement: step 7, image 1 of 3 Hover-1 Charger Battery Replacement: step 7, image 2 of 3 Hover-1 Charger Battery Replacement: step 7, image 3 of 3
      • On the battery side, unplug the white five pin connector on the circuitboard.
      • Unplug the black, yellow, green and red connector on the circuitboard.
      Ask FixBot
    8. Hover-1 Charger Battery Replacement: step 8, image 1 of 1
      • Move all the loose cables to the side. Pull the battery casing away from the battery.
      Ask FixBot
    9. Hover-1 Charger Battery Replacement: step 9, image 1 of 1
      • Use the opening tool to remove the battery from the metal casing.
      • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
      Ask FixBot
    10. Hover-1 Charger Battery Replacement: step 10, image 1 of 1
      • Remove the battery.
      Ask FixBot
3 other people completed this guide.
Melanie Hardell
547 Reputation
2 Guides authored
Cal Poly, Team S12-G1, Regan Fall 2019 Member of Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Members
72 Guides authored
1 Guide Comment
Can I replace my battery 25.2v to a 36v.
Airie Green - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 92
All Time: 10,762
