Hover-1 All Star Headlight Replacement
  1. Hover-1 All Star Headlight Replacement, Outer Casing: step 1, image 1 of 2 Hover-1 All Star Headlight Replacement, Outer Casing: step 1, image 2 of 2
    • Turn the hoverboard upside down and remove the twenty Phillips #1 screws that secure the casing.
    Ask FixBot
  2. Hover-1 All Star Headlight Replacement: step 2, image 1 of 2 Hover-1 All Star Headlight Replacement: step 2, image 2 of 2
    • After all the screws are removed simply pull off the bottom part of the casing in two pieces (Right and Left).
    Ask FixBot
  3. Hover-1 All Star Headlight Replacement, Battery: step 3, image 1 of 2 Hover-1 All Star Headlight Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery from the circuit board via the orange connector.
    Ask FixBot
  4. Hover-1 All Star Headlight Replacement: step 4, image 1 of 2 Hover-1 All Star Headlight Replacement: step 4, image 2 of 2
    • Remove the four small screws that secures the plastic battery bracket with a Phillips #1 screwdriver.
    • Remove the plastic bracket.
    • Once the plastic restraint is removed the battery will have nothing else holding it in but a piece of double sided tape on the bottom.
    Ask FixBot
  5. Hover-1 All Star Headlight Replacement: step 5, image 1 of 1
    • Remove the battery.
    • This step will likely require you to use the plastic prying tool because the tape is very strong.
    Ask FixBot
  6. Hover-1 All Star Headlight Replacement, Headlight: step 6, image 1 of 1
    • Disconnect the two-pin red and black headlight connectors.
    • Do not pull on the wires.
    Ask FixBot
  7. Hover-1 All Star Headlight Replacement: step 7, image 1 of 1
    • Remove the headlight assembly.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Nathan Meyer
629 Reputation
6 Guides authored
Cuesta, Team 10-2, Krynen Fall 2024 Member of Cuesta, Team 10-2, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 165
