Hover-1 All Star Battery Replacement
  1. Hover-1 All Star Battery Replacement, Outer Casing: step 1, image 1 of 2 Hover-1 All Star Battery Replacement, Outer Casing: step 1, image 2 of 2
    • Turn the hoverboard upside down and remove the twenty Phillips #1 screws that secure the casing.
    Ask FixBot
  2. Hover-1 All Star Battery Replacement: step 2, image 1 of 2 Hover-1 All Star Battery Replacement: step 2, image 2 of 2
    • After all the screws are removed simply pull off the bottom part of the casing in two pieces (Right and Left).
    Ask FixBot
  3. Hover-1 All Star Battery Replacement, Battery: step 3, image 1 of 2 Hover-1 All Star Battery Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery from the circuit board via the orange connector.
    Ask FixBot
  4. Hover-1 All Star Battery Replacement: step 4, image 1 of 2 Hover-1 All Star Battery Replacement: step 4, image 2 of 2
    • Remove the four small screws that secures the plastic battery bracket with a Phillips #1 screwdriver.
    • Remove the plastic bracket.
    • Once the plastic restraint is removed the battery will have nothing else holding it in but a piece of double sided tape on the bottom.
    Ask FixBot
  5. Hover-1 All Star Battery Replacement: step 5, image 1 of 1
    • Remove the battery.
    • This step will likely require you to use the plastic prying tool because the tape is very strong.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Nathan Meyer
629 Reputation
6 Guides authored
Cuesta, Team 10-2, Krynen Fall 2024 Member of Cuesta, Team 10-2, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 51
All Time: 566
