Introduction
This guide will help you replace the two motherboards inside your Hover-1 Eclipse. The motherboard serves as a unit that houses and connects all the different computer components. To replace the motherboard you must be cautious when navigating the internal wires that connect to it and be comfortable with disconnecting various wires.
Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
Remove the right side bottom shell piece.
On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
Now you can fully remove the bottom left shell piece.
7 Guide Comments
We’re do you get the boards at I really need them
We’re do get the boards?
Any idea where to buy parts and the price?
