Hover 1 Eclipse Charging Port Replacement
  1. Hover 1 Eclipse Charging Port Replacement, Charging Port: step 1, image 1 of 2 Hover 1 Eclipse Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
    • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
    • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
    Ask FixBot
  2. Hover 1 Eclipse Charging Port Replacement: step 2, image 1 of 1
    • Unscrew the ring around the inside section of the charging port.
    Ask FixBot
  3. Hover 1 Eclipse Charging Port Replacement: step 3, image 1 of 1
    • Follow the wire back from the charging port to where it plugs into the board.
    • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
    Ask FixBot
  4. Hover 1 Eclipse Charging Port Replacement: step 4, image 1 of 2 Hover 1 Eclipse Charging Port Replacement: step 4, image 2 of 2
    • Pull the charging port and wire attached to it out through the front side of the port.
    • Take the plastic protector off of the charging port.
    Ask FixBot
Mina Dedijer
548 Reputation
4 Guides authored
Cal Poly, Team S12-G4, Regan Fall 2019 Member of Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,089
