Up to 20% off select tools
Housing Disassembly
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
91
All Time:
1,084
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Housing Disassembly
Tools
Introduction
Go to step 1 ↓
In order to replace most parts in this saw, you will first need to remove this housing by unscrewing the nine screws located around the saw. If the housing is either broken or cracked. It can be easily replaced by following the steps below.
    1. Housing Disassembly, Housing Disassembly: step 1, image 1 of 2 Housing Disassembly, Housing Disassembly: step 1, image 2 of 2
      • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
      Ask FixBot
    2. Housing Disassembly: step 2, image 1 of 1
      • By separating the two housing halves, carefully remove the top plate.
      Ask FixBot
2 other people completed this guide.
Author
with
matt murray
682 Reputation
6 Guides authored
Cal Poly, Team 22-9, Maness Winter 2017 Member of Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 91
All Time: 1,084
