Hott T725-8G Screen/Display Replacement
    1. Hott T725-8G Screen/Display Replacement, Screen/Display: step 1, image 1 of 1
      • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
      Ask FixBot
    2. Hott T725-8G Screen/Display Replacement: step 2, image 1 of 1
      • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
      Ask FixBot
    3. Hott T725-8G Screen/Display Replacement: step 3, image 1 of 1
      • Dislodge the sensor from the front panel.
      Ask FixBot
    4. Hott T725-8G Screen/Display Replacement: step 4, image 1 of 2 Hott T725-8G Screen/Display Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
      Ask FixBot
    5. Hott T725-8G Screen/Display Replacement: step 5, image 1 of 3 Hott T725-8G Screen/Display Replacement: step 5, image 2 of 3 Hott T725-8G Screen/Display Replacement: step 5, image 3 of 3
      • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
      Ask FixBot
    6. Hott T725-8G Screen/Display Replacement: step 6, image 1 of 1
      • Follow the guide to remove the motherboard from the back of the display.
      Ask FixBot
    7. Hott T725-8G Screen/Display Replacement: step 7, image 1 of 1
      • Follow the guide to remove the battery from the back of the display.
      Ask FixBot
    8. Hott T725-8G Screen/Display Replacement: step 8, image 1 of 1
      • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
      Ask FixBot
    9. Hott T725-8G Screen/Display Replacement: step 9, image 1 of 1
      • Remove Digitizer Panel from the front panel.
      Ask FixBot
    10. Hott T725-8G Screen/Display Replacement: step 10, image 1 of 1
      • Remove the LCD 5-Point Touch Screen from the display case.
      Ask FixBot
    11. Hott T725-8G Screen/Display Replacement: step 11, image 1 of 1
      • Remove the display from the plastic casing. The screen is now ready for replacement.
      Ask FixBot
2 other people completed this guide.
Emma Carroll
220 Reputation
5 Guides authored
UMass Dartmouth, Team 6-2, Martin Fall 2016 Member of UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 590
