Hott T725-8G Motherboard Replacement
    1. Hott T725-8G Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Carefully remove the black electrical tape connecting the motherboard to the ribbon wire.
      Ask FixBot
    2. Hott T725-8G Motherboard Replacement: step 2, image 1 of 3 Hott T725-8G Motherboard Replacement: step 2, image 2 of 3 Hott T725-8G Motherboard Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Squeeze both sides of the protector over the ribbon wire to release it.
      • Use the tweezers to gently remove the ribbon wire from the holder.
      • Repeat steps for all three ribbon wires shown.
      Ask FixBot
    3. Hott T725-8G Motherboard Replacement: step 3, image 1 of 3 Hott T725-8G Motherboard Replacement: step 3, image 2 of 3 Hott T725-8G Motherboard Replacement: step 3, image 3 of 3
      • Use the #000 Phillips screw driver to remove all three 2.2mm screws attached to the mother board.
      Ask FixBot
You are now able to remove the motherboard.
Jason Dorsey
127 Reputation
1 Guide authored
UMass Dartmouth, Team 6-2, Martin Fall 2016 Member of UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 69
All Time: 581
