Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
78
All Time:
1,614
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Your Hot Wheels AI Intelligent Race System controller may fail to respond or lag, even when the cars are working perfectly. You will need a #J1 Philips head screw driver for repairs. Be cautious when removing casing as wires are prone to disconnecting or breaking. Use caution when removing circuits as wires can get stuck and circuits can be damaged.
Tools
    1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: step 1, image 1 of 1
      • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
      Ask FixBot
    2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: step 2, image 1 of 1
      • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
      Ask FixBot
    3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: step 3, image 1 of 1
      • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
      Ask FixBot
    4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: step 4, image 1 of 1
      • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
      Ask FixBot
    5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: step 5, image 1 of 1
      • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
      • Replace transmitter circuit with a new one by reinserting it into the original slot.
      Ask FixBot
1 Guide Comment
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 78
All Time: 1,614
