Hori Real Arcade Pro N Push Button Replacement
    1. Hori Real Arcade Pro N Push Button Replacement, Push Button: step 1, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement, Push Button: step 1, image 2 of 2
      • Flip your Fight Stick so the bottom is facing up.
      • Remove the sticker covering the screw in the bottom middle of the device.
      • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
      Ask FixBot
    2. Hori Real Arcade Pro N Push Button Replacement: step 2, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 2, image 2 of 2
      • Find the storage compartment that holds the USB wire.
      • Open the case by putting your hand in the compartment and pushing up.
      • Put your Fight Stick on its side to make the other steps easier.
      Ask FixBot
    3. Hori Real Arcade Pro N Push Button Replacement: step 3, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 3, image 2 of 2
      • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
      • Pulling the wire instead of the black grip can cause the wires to not function.
      Ask FixBot
    4. Hori Real Arcade Pro N Push Button Replacement: step 4, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 4, image 2 of 2
      • Twist the button you are planning to remove.
      • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
      Ask FixBot
    5. Hori Real Arcade Pro N Push Button Replacement: step 5, image 1 of 3 Hori Real Arcade Pro N Push Button Replacement: step 5, image 2 of 3 Hori Real Arcade Pro N Push Button Replacement: step 5, image 3 of 3
      • Squeeze the tabs in the button.
      • While squeezing, push the button inward, so it falls out.
      Ask FixBot
2 other people completed this guide.
gabriel garcia
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 65
All Time: 2,805
