Up to 20% off select tools
Hoover Power Path Pro Advanced Suction Motor Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
104
All Time:
3,216
Comments: 11
10 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Very difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
The suction motor is at the core of the proper function of any household floor cleaner. This guide will demonstrate how to properly replace a broken suction motor.
    1. Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: step 1, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: step 1, image 2 of 2
      • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
      • Lay the cleaner down horizontally with its wheels closest to the floor.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Suction Motor Replacement: step 2, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement: step 2, image 2 of 2
      • Hold the lower brush roll with both hands and pull outwards until it is detached.
      Ask FixBot
    3. Hoover Power Path Pro Advanced Suction Motor Replacement: step 3, image 1 of 1
      • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
      • Remove the brush roller.
      Ask FixBot
    1. Hoover Power Path Pro Advanced Suction Motor Replacement, Belt: step 4, image 1 of 1
      • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Suction Motor Replacement: step 5, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement: step 5, image 2 of 2
      • Pull the red handle shown to remove the front suction unit from the cleaner.
      Ask FixBot
    3. Hoover Power Path Pro Advanced Suction Motor Replacement: step 6, image 1 of 1
      • Unscrew the Phillips #2 screw at the bottom of the hose.
      Ask FixBot
    4. Hoover Power Path Pro Advanced Suction Motor Replacement: step 7, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement: step 7, image 2 of 2
      • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
      • Repeat the above step for the "On/Off" button.
      • When pulling the handle release button, make sure the top of the cleaner does not fall.
      Ask FixBot
    5. Hoover Power Path Pro Advanced Suction Motor Replacement: step 8, image 1 of 1
      • Gently grab the belt and pry it off from the rollers.
      Ask FixBot
    1. Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: step 9, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: step 9, image 2 of 2
      • Unscrew two screws using Phillips #2 screwdriver.
      • Detach grey piece from vacuum.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Suction Motor Replacement: step 10, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement: step 10, image 2 of 2
      • Unscrew four screws using a Phillips 2 screwdriver.
      Ask FixBot
    3. Hoover Power Path Pro Advanced Suction Motor Replacement: step 11, image 1 of 1
      • Pull out of base of vacuum.
      Ask FixBot
    4. Hoover Power Path Pro Advanced Suction Motor Replacement: step 12, image 1 of 1
      • Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
      Ask FixBot
    5. Hoover Power Path Pro Advanced Suction Motor Replacement: step 13, image 1 of 1
      • Unscrew two screws with Phillips #2 screwdriver.
      Ask FixBot
    6. Hoover Power Path Pro Advanced Suction Motor Replacement: step 14, image 1 of 1
      • Detach motor and unscrew two screws with a Phillips #2 screwdriver.
      Ask FixBot
    7. Hoover Power Path Pro Advanced Suction Motor Replacement: step 15, image 1 of 2 Hoover Power Path Pro Advanced Suction Motor Replacement: step 15, image 2 of 2
      • Pull the bottom section off.
      • Pull the cap off.
      Ask FixBot
4 other people completed this guide.
Author
with
Jose Andres Gonzalez Valdes
682 Reputation
5 Guides authored
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
108 Guides authored
1 Guide Comment
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - Reply Share
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 104
All Time: 3,216
