Up to 20% off select tools
Hoover Power Path Pro Advanced Power Switch Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
102
All Time:
4,687
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The power switch allows the Hoover Power Path Pro Advanced to turn on with the press of the power button. A defective power switch will not allow the user to control the on and off state of the device and needs to be replaced.
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Remove the lower brushroll from the bottom of the cleaner.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Power Switch Replacement: step 2, image 1 of 1
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      Ask FixBot
    3. Hoover Power Path Pro Advanced Power Switch Replacement: step 3, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 3, image 2 of 2
      • Pull the red handle to remove the front suction unit from the cleaner.
      Ask FixBot
    4. Hoover Power Path Pro Advanced Power Switch Replacement: step 4, image 1 of 1
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      Ask FixBot
    5. Hoover Power Path Pro Advanced Power Switch Replacement: step 5, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 5, image 2 of 2
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      Ask FixBot
    6. Hoover Power Path Pro Advanced Power Switch Replacement: step 6, image 1 of 1
      • Remove the "On/Off" cap by pulling it upwards with caution.
      Ask FixBot
    7. Hoover Power Path Pro Advanced Power Switch Replacement: step 7, image 1 of 1
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      Ask FixBot
    8. Hoover Power Path Pro Advanced Power Switch Replacement: step 8, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 8, image 2 of 2
      • Pull out the red power the red power switch.
      Ask FixBot
4 other people completed this guide.
Author
with
Jose Andres Gonzalez Valdes
682 Reputation
5 Guides authored
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
108 Guides authored
3 Guide Comments
What is the part number?
martahayner - Reply Share
Thanks so much!!
debmccrimm - Reply Share
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 102
All Time: 4,687
