Hoover Power Path Pro Advanced Hose Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
102
All Time:
5,335
Comments: 10
6 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The hose creates a pathway for water to flow from the dirty and clean water tanks on your Hoover Power Path Pro Advanced. However, if there is a puncture in the hose, then it needs to be replaced.
Tools
    1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: step 1, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: step 1, image 2 of 2
      • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
      • Lay the cleaner down horizontally with its wheels closest to the floor.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Hose Replacement: step 2, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement: step 2, image 2 of 2
      • Hold the lower brush roll with both hands and pull outwards until it is detached.
      Ask FixBot
    3. Hoover Power Path Pro Advanced Hose Replacement: step 3, image 1 of 1
      • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
      • Remove the brush roller.
      Ask FixBot
    1. Hoover Power Path Pro Advanced Hose Replacement, Hose: step 4, image 1 of 1
      • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
      • They will also be indicated on the bottom of the vacuum.
      Ask FixBot
    2. Hoover Power Path Pro Advanced Hose Replacement: step 5, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement: step 5, image 2 of 2
      • Pull the red handle shown to remove the front suction unit from the cleaner.
      Ask FixBot
    3. Hoover Power Path Pro Advanced Hose Replacement: step 6, image 1 of 1
      • Unscrew the Phillips #2 screw at the bottom of the hose.
      Ask FixBot
    4. Hoover Power Path Pro Advanced Hose Replacement: step 7, image 1 of 1
      • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
      Ask FixBot
3 other people completed this guide.
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
108 Guides authored
4 Guide Comments
Where can I find this replacement hose?
Jennifer - Reply Share
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Reply Share
Where can I purchase the lower hose?
Eryk H. - Reply Share
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 102
All Time: 5,335
