Hoover LiNX Power Button Replacement
    1. Hoover LiNX Power Button Replacement, Hoover LiNX Handle Teardown: step 1, image 1 of 1
      • Remove the single 15mm Phillips #1 screw from the handle.
      Ask FixBot
    2. Hoover LiNX Power Button Replacement: step 2, image 1 of 1
      • Remove the handle by pulling it up.
      Ask FixBot
    3. Hoover LiNX Power Button Replacement: step 3, image 1 of 1
      • Remove two 15mm Phillips #1 screws from the handle.
      Ask FixBot
    4. Hoover LiNX Power Button Replacement: step 4, image 1 of 2 Hoover LiNX Power Button Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to carefully pry the black cover off of the handle.
      Ask FixBot
    5. Hoover LiNX Power Button Replacement: step 5, image 1 of 2 Hoover LiNX Power Button Replacement: step 5, image 2 of 2
      • Remove five 15mm Phillips #1 black screws from the handle.
      Ask FixBot
    6. Hoover LiNX Power Button Replacement: step 6, image 1 of 2 Hoover LiNX Power Button Replacement: step 6, image 2 of 2
      • Remove the silver plastic cover using the plastic opening tool.
      Ask FixBot
    1. Hoover LiNX Power Button Replacement, The Motherboard Inside The Handle: step 7, image 1 of 1
      • Remove the black rubber cover from the motherboard.
      Ask FixBot
    2. Hoover LiNX Power Button Replacement: step 8, image 1 of 1
      • Remove two 8mm Phillips #1 screws from the motherboard.
      Ask FixBot
    3. Hoover LiNX Power Button Replacement: step 9, image 1 of 2 Hoover LiNX Power Button Replacement: step 9, image 2 of 2
      • Carefully pull the motherboard out with its attached wires.
      Ask FixBot
    1. Hoover LiNX Power Button Replacement, Power Button: step 10, image 1 of 2 Hoover LiNX Power Button Replacement, Power Button: step 10, image 2 of 2
      • Replace the power button.
      Ask FixBot
2 other people completed this guide.
Mark Nelson
452 Reputation
2 Guides authored
USF Tampa, Team S7-G4, Passmore Spring 2018 Member of USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 34
All Time: 1,864
