Honeywell HY-204 Rotation Button Replacement
  1. Honeywell HY-204 Rotation Button Replacement, Case: step 1, image 1 of 2 Honeywell HY-204 Rotation Button Replacement, Case: step 1, image 2 of 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
    Ask FixBot
  2. Honeywell HY-204 Rotation Button Replacement: step 2, image 1 of 2 Honeywell HY-204 Rotation Button Replacement: step 2, image 2 of 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
    Ask FixBot
  3. Honeywell HY-204 Rotation Button Replacement, Control Panel: step 3, image 1 of 2 Honeywell HY-204 Rotation Button Replacement, Control Panel: step 3, image 2 of 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
    Ask FixBot
  4. Honeywell HY-204 Rotation Button Replacement: step 4, image 1 of 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
    Ask FixBot
  5. Honeywell HY-204 Rotation Button Replacement, Rotation Button: step 5, image 1 of 2 Honeywell HY-204 Rotation Button Replacement, Rotation Button: step 5, image 2 of 2
    • Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
    Ask FixBot
  6. Honeywell HY-204 Rotation Button Replacement: step 6, image 1 of 1
    • Peel back the heat shrink tubing on both wires connecting to the button.
    Ask FixBot
  7. Honeywell HY-204 Rotation Button Replacement: step 7, image 1 of 1
    • Caution The soldering iron is very hot, be careful to avoid burns.
    • Desolder the two wires connected to the button and remove the button.
    Ask FixBot
Nolan Ernotte
384 Reputation
3 Guides authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 39
All Time: 1,266
