Honeywell HY-204 Control Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
91
All Time:
999
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is necessary to complete before many of our other replacement guides, but it can also stand alone as a replacement guide for the control panel. This is a really simple guide and should only take you a few minutes!
Tools
    1. Honeywell HY-204 Control Panel Replacement, Case: step 1, image 1 of 2 Honeywell HY-204 Control Panel Replacement, Case: step 1, image 2 of 2
      • Before you begin, be sure to unplug the fan.
      • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
      Ask FixBot
    2. Honeywell HY-204 Control Panel Replacement: step 2, image 1 of 2 Honeywell HY-204 Control Panel Replacement: step 2, image 2 of 2
      • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
      Ask FixBot
    1. Honeywell HY-204 Control Panel Replacement, Control Panel: step 3, image 1 of 2 Honeywell HY-204 Control Panel Replacement, Control Panel: step 3, image 2 of 2
      • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
      Ask FixBot
    2. Honeywell HY-204 Control Panel Replacement: step 4, image 1 of 1
      • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
      Ask FixBot
Nolan Ernotte
384 Reputation
3 Guides authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 91
All Time: 999
