Honda civic 2019 Trunk Strut Replacement
  1. Honda civic 2019 Trunk Strut Replacement, Trunk Strut: step 1, image 1 of 1
    • Open the trunk and use an object like a pole or a broomstick to securely prop it open. You may prefer to have another person hold the trunk open while making the repair. Hazard: If not properly supported, the trunk may fall during the repair causing potential injury.
    Ask FixBot
  2. Honda civic 2019 Trunk Strut Replacement: step 2, image 1 of 1
    • Locate the trunk strut on the far-left side of the trunk. Wedge a flat-head screwdriver below the small ring at the top of the strut. Use the screwdriver as a lever to pop out this ring, loosening the connection between the strut and the car.
    Ask FixBot
  3. Honda civic 2019 Trunk Strut Replacement: step 3, image 1 of 1
    • Pull the top of the strut horizontally until it is removed from the ball joint.
    Ask FixBot
  4. Honda civic 2019 Trunk Strut Replacement: step 4, image 1 of 1
    • Locate the other ring at the bottom of this same strut. Use a flat-head screwdriver to again pry up the ring.
    Ask FixBot
  5. Honda civic 2019 Trunk Strut Replacement: step 5, image 1 of 1
    • Pull the bottom of the strut horizontally until it is removed from the ball joint.
    Ask FixBot
  6. Honda civic 2019 Trunk Strut Replacement: step 6, image 1 of 1
    • Now that the left trunk strut is fully detached from the car body, install the new trunk strut by pushing the sockets of the strut into the ball joints where the old strut was removed.
    Ask FixBot
  7. Honda civic 2019 Trunk Strut Replacement: step 7, image 1 of 2 Honda civic 2019 Trunk Strut Replacement: step 7, image 2 of 2
    • Repeat Steps 2-6 for the right trunk strut. Make sure that the left trunk strut has been fully replaced before detaching the right trunk strut.
    Ask FixBot
Peyton Batte
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 64
All Time: 1,360
