Honda civic 2016 Keyless Remote Battery Replacement
    1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: step 1, image 1 of 2 Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: step 1, image 2 of 2
      • Make sure to have replacement battery ready. You will need 1 pc of CR 2032 Lithium battery.
      • Remove the metal key by sliding the switch on the back of the remote and pulling the key out.
      Ask FixBot
    2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: step 2, image 1 of 3 Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: step 2, image 2 of 3 Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: step 2, image 3 of 3
      • After removing the key, you will see 2 plastic bars. This is a place where you can split the remote open.
      • The manufacturer recommeded using a coin but any hard tool or even the key itself will work as well.
      • The manufacturer recommended using a cloth covering your coin/ tool to prevent it from denting the plastic bars.
      Ask FixBot
    3. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: step 3, image 1 of 3 Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: step 3, image 2 of 3 Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: step 3, image 3 of 3
      • Now you can gently pry it open
      • Removing the old battery from the left side.
      • Remember that the + side of the battery is facing up.
      Ask FixBot
    4. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: step 4, image 1 of 2 Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: step 4, image 2 of 2
      • Inserting a new CR 2032 battery from the right side first and then press the battery down. It should make a good 'click' sound
      • Again, make sure the + side of the battery is facing upward.
      Ask FixBot
18 other people completed this guide.
Anan Venasakulchai
1,059 Reputation
2 Guides authored
Finn Store Member of Finn Store
Business
1 Member
24 Guides authored
1 Guide Comment
Super Anleitung mit sehr guten Fotos - vielen Dank!
Philipp Glück - Reply Share
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 182
All Time: 61,661
