Honda FC600 Tiller Throttle Cable Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
9
Past 7 Days:
36
Past 30 Days:
129
All Time:
3,355
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace a worn or damaged throttle cable on the Honda FC600 tiller. Be sure to follow all safety precautions listed in the tiller’s user manual when working on or operating the machine.
    1. Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: step 1, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: step 1, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: step 1, image 3 of 3
      • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
      • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
      Ask FixBot
    1. Honda FC600 Tiller Throttle Cable Replacement, Preparation: step 2, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement, Preparation: step 2, image 2 of 2
      • Push the throttle lever all the way down.
      Ask FixBot
    2. Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Lever: step 3, image 1 of 1
      • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
      • This screw is accompanied by a square nut. Be sure to retain it for reassembly.
      Ask FixBot
    3. Honda FC600 Tiller Throttle Cable Replacement, Remove the Small Throttle Cable Clip: step 4, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement, Remove the Small Throttle Cable Clip: step 4, image 2 of 2
      • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
      Ask FixBot
    4. Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Cable: step 5, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Cable: step 5, image 2 of 2
      • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
      Ask FixBot
    5. Honda FC600 Tiller Throttle Cable Replacement: step 6, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 6, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 6, image 3 of 3
      • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
      Ask FixBot
    1. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter Cover: step 7, image 1 of 1
      • Use your fingers to unscrew and remove the wing nut securing the air filter cover to the air filter elbow.
      Ask FixBot
    2. Honda FC600 Tiller Throttle Cable Replacement: step 8, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement: step 8, image 2 of 2
      • Lift up and remove the air filter cover to reveal the air filter.
      • The air filter cover will still be attached to the tiller by a flexible hose. You can push the cover to the side while you continue to work on the tiller, or follow the next two steps to completely remove the cover.
      Ask FixBot
    3. Honda FC600 Tiller Throttle Cable Replacement, Detach the Air Filter Cover: step 9, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement, Detach the Air Filter Cover: step 9, image 2 of 2
      • The next two steps are optional, but they will make it easier to work on the tiller from here on out.
      • Squeeze the metal clip on the inside of the air filter cover and remove it.
      Ask FixBot
    4. Honda FC600 Tiller Throttle Cable Replacement: step 10, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement: step 10, image 2 of 2
      • Hold onto the air filter hose and pull on the air filter cover to remove it.
      Ask FixBot
    5. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter: step 11, image 1 of 1
      • Use your fingers to unscrew and remove the wing nut securing the air filter to the air filter elbow.
      Ask FixBot
    6. Honda FC600 Tiller Throttle Cable Replacement: step 12, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement: step 12, image 2 of 2
      • Wear gloves or use a rag during this step, as the air filter is coated with oil.
      • Lift the air filter straight up off the elbow, making sure it clears the threaded rod.
      Ask FixBot
    7. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter Elbow: step 13, image 1 of 1
      • Use a 10 mm socket and socket wrench to remove the 25.5 mm-long bolt securing the air filter elbow to the tiller.
      Ask FixBot
    8. Honda FC600 Tiller Throttle Cable Replacement: step 14, image 1 of 1
      • Use a 10 mm socket and socket wrench to remove the two nuts securing the air filter elbow to the carburetor's threaded rods.
      Ask FixBot
    9. Honda FC600 Tiller Throttle Cable Replacement: step 15, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 15, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 15, image 3 of 3
      • Use a pair of snap ring pliers to loosen the spring hose clamp on the breather tube, pulling it out 2-3 cm so it's not clamping onto the end of the tube.
      Ask FixBot
    10. Honda FC600 Tiller Throttle Cable Replacement: step 16, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement: step 16, image 2 of 2
      • Pull the air filter elbow straight off, making sure it clears the carburetor's threaded rods.
      • As you remove the elbow, you may need to use your other hand to remove the breather tube from the engine's valve cover.
      Ask FixBot
    1. Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: step 17, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: step 17, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: step 17, image 3 of 3
      • Insert a flathead screwdriver in between the release tab and the tip of the cable tie securing the throttle cable to the handlebar.
      • Twist the screwdriver to separate the release tab and loosen the cable tie.
      • Repeat this step for the remaining cable ties.
      Ask FixBot
    2. Honda FC600 Tiller Throttle Cable Replacement: step 18, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 18, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 18, image 3 of 3
      • Pull the throttle cable out of the cable holder underneath the handle column.
      Ask FixBot
    3. Honda FC600 Tiller Throttle Cable Replacement: step 19, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 19, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 19, image 3 of 3
      • Use a pair of needle nose pliers to bend the metal clip at the bottom of the handle column out and upward.
      Ask FixBot
    4. Honda FC600 Tiller Throttle Cable Replacement: step 20, image 1 of 2 Honda FC600 Tiller Throttle Cable Replacement: step 20, image 2 of 2
      • Use a pair of needle nose pliers to bend the last section of the metal clip outward to release the throttle cable.
      Ask FixBot
    5. Honda FC600 Tiller Throttle Cable Replacement: step 21, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 21, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 21, image 3 of 3
      • Grab the end of the throttle cable with your fingers and push the cable inwards so that it lines up with the small cutout on the control lever.
      • Lift the throttle cable straight up to free it from the control lever.
      Ask FixBot
    6. Honda FC600 Tiller Throttle Cable Replacement: step 22, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 22, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 22, image 3 of 3
      • Grab onto the end of the throttle cable housing and pull it out of its holder on the control lever.
      • Lift the throttle cable straight up to completely remove it from the control lever.
      Ask FixBot
    7. Honda FC600 Tiller Throttle Cable Replacement: step 23, image 1 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 23, image 2 of 3 Honda FC600 Tiller Throttle Cable Replacement: step 23, image 3 of 3
      • Pull the throttle cable all the way out, fishing it through the clips, cable ties, and guides.
      Ask FixBot
Craig Lloyd
43,716 Reputation
82 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 129
All Time: 3,355
