Honda Accord Car Key Remote
    1. Honda Accord Car Key Remote, Replacing the battery: step 1, image 1 of 2 Honda Accord Car Key Remote, Replacing the battery: step 1, image 2 of 2
      • Locate the screw in the middle of your car key.
      • Make sure you have the following tools - Tri-point Screwdriver - CR2032 Battery
      Ask FixBot
    2. Honda Accord Car Key Remote: step 2, image 1 of 1
      • With your screwdriver, begin to screw in a counter-clockwise motion.
      Ask FixBot
    3. Honda Accord Car Key Remote: step 3, image 1 of 1
      • Each key should have a small gap. Locate this gap on the side of your key.
      • After you have taken off the screw, place the small screw somewhere safe. Then with the same screwdriver or a flathead screwdriver, you want to apply pressure to the small gap to pop it open.
      Ask FixBot
    4. Honda Accord Car Key Remote: step 4, image 1 of 3 Honda Accord Car Key Remote: step 4, image 2 of 3 Honda Accord Car Key Remote: step 4, image 3 of 3
      • This is an example of how the key should look after you pop it open.
      Ask FixBot
    5. Honda Accord Car Key Remote: step 5, image 1 of 1
      • Do not touch the other half of the key
      • After popping open the key, the battery should be located on the left half of the key.
      Ask FixBot
    6. Honda Accord Car Key Remote: step 6, image 1 of 1
      • Apply pressure with the flathead screwdriver, and the battery should pop out once again.
      Ask FixBot
    7. Honda Accord Car Key Remote: step 7, image 1 of 2 Honda Accord Car Key Remote: step 7, image 2 of 2
      • swap the old battery with the new battery
      • Make sure the smooth part of the battery is facing inside and not facing outwards as shown on the picture
      Ask FixBot
    8. Honda Accord Car Key Remote: step 8, image 1 of 1
      • Lastly, place the key back together and screw the middle part back with the tri-point screwdriver.
      Ask FixBot
Emerson Corado
157 Reputation
1 Guide authored
1 Guide Comment
You listed the wrong battery. It uses a CR1620 not a CR2032. Your picture even shows the correct battery. Also I believe it is a P000 screwdriver, that is what fit my 2013 Accord key.
Mark Fox - Reply Share
Past 24 Hours: 7
Past 7 Days: 19
Past 30 Days: 52
All Time: 893
