Up to 20% off select tools
Homelite UT44172 Plastic Casing Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
92
All Time:
855
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
The Homelite 4.8 Volt Cordless Grass Shear (model UT44172), also known as the Homelite Trimmer UT44172, Homelite UT44172 Shear, or Homelite UT44172 Cordless Grass Shears, use this guide to replace the plastic casing.
The plastic casing serves as protection for internal components such as the motor, internal wiring, and rechargeable battery as well as safety protection, safely housing a safety switch, ensuring the blades are not engaged unless activated manually.
Signs that the plastic casing might be compromised may be visual: cracks or splits on the casing and debris intrusions, such as grass, dirt, or foliage within the device. Other symptoms of a compromised plastic casing exist as operational and mechanical signs, such as a sticky or loose safety switch, excessive vibration or noise, or blade misalignment (loose or wobbly blades).
For more information on these symptoms, see the Homelite UT44172 trouble shooting page.
To prevent unintentionally activating the blades, make sure to take the battery out of the device before starting. Use caution when handling loose internal wires during the replacement process to avoid damaging connections.
For the operator's manual and additional device information, see the Homelite UT44172 user manual.
    1. Homelite UT44172 Plastic Casing Replacement, Opening Device: step 1, image 1 of 1
      • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
      Ask FixBot
    2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: step 2, image 1 of 2 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: step 2, image 2 of 2
      • Pull the faceplate away from the body of the device and replace it with the new faceplate.
      • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
      • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
      Ask FixBot
Author
with
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 92
All Time: 855
