Up to 20% off select tools
Homelite UT44172 Operating Switch Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
86
All Time:
782
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 7 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If you are having problems turning on the shear or the operating switch seems too loose, this guide might be useful for replacing the part.
    1. Homelite UT44172 Operating Switch Replacement, Opening Device: step 1, image 1 of 1
      • Use a Philips-head screwdriver to remove the six, 15 mm screws from the casing.
      Ask FixBot
    2. Homelite UT44172 Operating Switch Replacement, Remove Faceplate: step 2, image 1 of 1
      • Remove the faceplate from the main body of the device, lift it and expose the inner mechanisms.
      Ask FixBot
    3. Homelite UT44172 Operating Switch Replacement, Switch Removal: step 3, image 1 of 2 Homelite UT44172 Operating Switch Replacement, Switch Removal: step 3, image 2 of 2
      • Locate and remove the operating switch from the device.
      Ask FixBot
    4. Homelite UT44172 Operating Switch Replacement, Spring Replacement: step 4, image 1 of 1
      • Replace the spring if it is deformed or broken.
      • Be careful that the wires do not get caught in the spring when replacing it.
      Ask FixBot
Author
with
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 86
All Time: 782
