Homedics UHE-CMP15 Water Replacement
  1. Homedics UHE-CMP15 Water Replacement, Water: step 1, image 1 of 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
    Ask FixBot
  2. Homedics UHE-CMP15 Water Replacement: step 2, image 1 of 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
    Ask FixBot
  3. Homedics UHE-CMP15 Water Replacement: step 3, image 1 of 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
    Ask FixBot
  4. Homedics UHE-CMP15 Water Replacement: step 4, image 1 of 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
    Ask FixBot
Dylan
337 Reputation
3 Guides authored
UMass Dartmouth, Team 3-6, Konn Fall 2023 Member of UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 430
