Homedics UHE-CMP15 Battery Replacement
  1. Homedics UHE-CMP15 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
    • Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
    Ask FixBot
  2. Homedics UHE-CMP15 Battery Replacement: step 2, image 1 of 1
    • Flip the top portion upside down and remove the wick and wick holder.
    • To remove the wick pull on the wick holder and it should pop right off.
    Ask FixBot
  3. Homedics UHE-CMP15 Battery Replacement: step 3, image 1 of 2 Homedics UHE-CMP15 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers and or the spudging tool lift 3 small white rubber caps, pry underneath them and pull to remove them.
    • This reveals the three screws holding the cap in place.
    Ask FixBot
  4. Homedics UHE-CMP15 Battery Replacement: step 4, image 1 of 1
    • Unscrew and remove the 3 screws with a Philips head screwdriver. The screwdriver must be very long and thin.
    • Tilting the device upside down will slide the unscrewed screws out from the holes they are in after they are loosened.
    Ask FixBot
  5. Homedics UHE-CMP15 Battery Replacement: step 5, image 1 of 3 Homedics UHE-CMP15 Battery Replacement: step 5, image 2 of 3 Homedics UHE-CMP15 Battery Replacement: step 5, image 3 of 3
    • The top portion will now be able to be removed to reveal the inside of the battery compartment.
    • The battery is glued to the side wall with an adhesive pad.
    • This battery is hardwired in, and will require skill in soldering/wiring and the ability to find a suitable replacement.
    Ask FixBot
Kade Betterton
267 Reputation
2 Guides authored
UMass Dartmouth, Team 3-6, Konn Fall 2023 Member of UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 40
All Time: 848
