Featured Document
This teardown is not a repair guide. To repair your HomePod Mini, use our service manual.
    1. HomePod Mini IC Identification, HomePod Mini IC Identification: step 1, image 1 of 1
      • Side 1 IC Identification, Pt. 1:
      • Apple APL1W82 64-Bit Dual-Core Applications Processor w/ GPU with likely 1 Gb LPDDR3 SDRAM Memory
      • This is the same processor found in the Apple Watch Series 5, just not protected by a boatload of epoxy.
      • Apple 338S00553-A0 Power Management
      • Nordic Semiconductor nRF52833 Bluetooth 5.2 SoC w/ NFC and Zigbee
      • Skyworks SKY66404-11 2.4 GHz Zigbee/Thread/Bluetooth Front-End Module
      • USI 339M00117 WiFi/Bluetooth Module
      • USI UWB Transceiver
      Ask FixBot
    2. HomePod Mini IC Identification: step 2, image 1 of 1
      • Side 1 IC Identification, Pt. 2:
      • Analog Devices SSM3582A 31.76 W Filterless Stereo Class D Audio Amplifier
      • Texas Instruments CD3217B12 USB Type C Controller
      • Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
      • Texas Instruments TPS62130B 3 A Step Down Converter
      • Texas Instruments INA199C3DCK Bi-Directional Current Sense Amplifier
      • Dialog Semiconductor SLG46140 Programmable Mixed Signal Array
      • 3 Likely Goertek MEMS Microphones are found around the perimeter of the PCB.
      Ask FixBot
    3. HomePod Mini IC Identification: step 3, image 1 of 1
      • Side 2 IC Identification:
      • Texas Instruments LP5030RJVR 30-Ch. Constant Current RGB LED Driver
      • Texas Instruments TPS55340RTE 5 A Boost Regulator
      • Austria Microsystems (AMS) Ambient Light Sensor
      Ask FixBot
    4. HomePod Mini IC Identification: step 4, image 1 of 3 HomePod Mini IC Identification: step 4, image 2 of 3 HomePod Mini IC Identification: step 4, image 3 of 3
      • Sensor Flex IC Identifications:
      • Texas Instruments HDC2010YPA Humidity/Temperature Sensor
      • Another likely Goertek MEMS Microphone
      Ask FixBot
Attached Documents
CChin
7,169 Reputation
7 Guides authored
3 Guide Comments
nRF52833 is used for Thread networking protocol. Refer to HomePod mini tech spec: https://www.apple.com/homepod-mini/specs...
Henry Churchill - Reply Share
I wonder when are they gonna allow homekit to access the temperature and humidity sensors of the homepod mini?
Jeremy - Reply Share
Hello, does anyone have any idea about the specs of the 2R2 inductor near the Texas Instruments TPS62130B 3 A Step Down Converter? Bought a dead HomePod Mini online to try and fix. I noticed that this component was missing on the board. Thank you!
Douglas Gee - Reply Share
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 194
All Time: 13,173
