Holystone HS 440 Drone Battery Replacement
  1. Holystone HS 440 Drone Battery Replacement, Drone Battery: step 1, image 1 of 2 Holystone HS 440 Drone Battery Replacement, Drone Battery: step 1, image 2 of 2
    • Pull the battery latch down and pull the battery out of the drone.
    • Make sure to turn off the drone before removing the battery.
  2. Holystone HS 440 Drone Battery Replacement: step 2, image 1 of 2 Holystone HS 440 Drone Battery Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four 4 mm Phillips #0 screws on the inside of the battery.
  3. Holystone HS 440 Drone Battery Replacement: step 3, image 1 of 1
    • After removing the four screws, purchase the replacement battery from the HolyStone product page
    • It is recommeded to charge the new battery bank before inserting it back into the drone
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 430
